Ga door naar hoofdinhoud
Toshiba Satellite C675-S7106 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C675-S7106 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Keyboard Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Keyboard Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 5, afbeelding 3 van 3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Keyboard Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite C675-S7106 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
Conclusie
Dinis Valcorba
292 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 456
