Ga door naar hoofdinhoud
Toshiba Satellite C675-S7106 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C675-S7106 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C675-S7106 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 1 van 2 Toshiba Satellite C675-S7106 Hard Drive Replacement, Hard Drive: stap 3, afbeelding 2 van 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Remove the lower-left plastic panel by loosening the single PH0-head screw and prying it up with a plastic spudger.
    • The screw does not need to be completely removed, as it's permanently attached to the device.
  4. Toshiba Satellite C675-S7106 Hard Drive Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite C675-S7106 Hard Drive Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite C675-S7106 Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove the existing drive by sliding it towards the left until it's disconnected, and then lift it out of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Dinis Valcorba
292 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 373
