Ga door naar hoofdinhoud
Toshiba Satellite C675-S7106 Battery Replacement
  1. Toshiba Satellite C675-S7106 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C675-S7106 Battery Replacement: stap 2, afbeelding 2 van 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
Conclusie
Joshua Steakelum
451 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Simcock Spring 2019 Lid van UMass Dartmouth, Team S1-G2, Simcock Spring 2019
UMASSD-SIMCOCK-S19S1G2
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 160
