Ga door naar hoofdinhoud
Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement
Wat je nodig hebt
  1. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): stap 1, afbeelding 1 van 2 Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): stap 1, afbeelding 2 van 2
    • Turn the laptop over and place upside down on a flat surface.
    • Remove the 5.5 mm "F5" screw with the Phillips #1 screwdriver and lift off plastic cover.
  2. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: stap 2, afbeelding 1 van 1
    • Take two fingers and gently pull the two metal tabs away from the RAM module as shown.
    • There are two tabs for each of the two RAM modules.
    • The RAM module should be slightly dislodged from the base after the two tabs are pulled.
  3. Toshiba Satellite C655D-S5084 Random Access Memory (RAM) Replacement: stap 3, afbeelding 1 van 1
    • Grip the edge of the card and slide the RAM module out by pulling horizontally.
    • Once the first RAM module has been removed, repeat steps 2 and 3 to remove the second RAM module.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Shelby Kunz
69 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-20, Maness Spring 2013 Lid van Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 3,059
