Ga door naar hoofdinhoud
Toshiba Satellite C655D-S5084 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 Toshiba Satellite C655D-S5084 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  2. Toshiba Satellite C655D-S5084 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  3. Toshiba Satellite C655D-S5084 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  4. Toshiba Satellite C655D-S5084 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Shelby Kunz
69 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-20, Maness Spring 2013 Lid van Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 22
Altijd: 3,372
