Inleiding
Is your computer getting too hot to handle? Overheating is a sign that your cooling fan may not be working properly, which may cause further damage to your computer. This guide will help you through the replacement of the cooling fan in your Toshiba Satellite C655D-S5084.
Wat je nodig hebt
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
Release all internal latches by working the slack around the motherboard.
This picture at step 16 shows the end result after all the cables that will be unplugged in steps 17-20 have been unplugged.
Furthermore, removing the keyboard before this allows easy access to the connectors mentioned in steps 17-20. The screws for the keyboard assembly are hidden under the strip of plastic above the top row of keys, or it least it is this way in other C655 sub-models.
9 andere personen hebben deze handleiding voltooid.
Één opmerking
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
