Ga door naar hoofdinhoud
Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement, CD/DVD Drive: stap 1, afbeelding 1 van 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  2. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: stap 2, afbeelding 1 van 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  3. Toshiba Satellite C655D-S5084 CD/DVD Drive Replacement: stap 3, afbeelding 1 van 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Shelby Kunz
69 Reputatie
5 handleidingen geschreven
Cal Poly, Team 2-20, Maness Spring 2013 Lid van Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 4,989
