Ga door naar hoofdinhoud
Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: stap 1, afbeelding 1 van 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: stap 1, afbeelding 2 van 3 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement, Cooling Fan and Heat Sink: stap 1, afbeelding 3 van 3
    • Turn the laptop off and remove any external power sources.
    • Flip the laptop upside down.
    • Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
  2. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
  3. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 3, afbeelding 2 van 2
    • Run the metal spudger around the seam between the back cover and the rest of the laptop.
    • Use the metal spudger to remove the bottom cover of the laptop.
  4. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 4, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to remove the screw securing the fan.
  5. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Loosen the four screws securing the heat sink using the same screwdriver.
    • These screws cannot be removed.
  6. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the fan from the motherboard by removing the white holder with the red, yellow, and black wires.
  7. Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite C55D-C5106 Cooling Fan and Heat Sink Replacement: stap 7, afbeelding 2 van 2
    • Pull the fan and heat sink away from the motherboard.
Conclusie
Laura Tamayo
678 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Spring 2019 Lid van USF Tampa, Team S1-G4, Leahy Spring 2019
USFT-LEAHY-S19S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 339
