Inleiding
If your Toshiba Satellite C55D-B5206 laptop is no longer able to connect to wireless networks, a faulty Wi-Fi Card may be the cause. The following guide will help you remove your current Wi-Fi card so that a replacement may be installed.
Wi-Fi cards allow your device to communicate to a nearby Wi-Fi access point, usually a router. Before deciding to replace your Wi-Fi card, try restarting the access point or connecting different devices to ensure the fault is originating from your laptop.
Prior to proceeding with the guide, power down your laptop and disconnect it from any external power supply.
Wat je nodig hebt
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
