Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Wi-Fi Card: stap 6, afbeelding 1 van 1
    • Unstick the silver tape from the area shown using a non-metallic tool.
  7. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 7, afbeelding 1 van 1
    • Remove the yellow tape to reveal the plug for the flat strip of wires.
  8. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 8, afbeelding 1 van 1
    • Locate the gray clips at either side of the plug. Use a non-metallic tool to push the clips away from the plug.
  9. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 9, afbeelding 1 van 1
    • Unplug the large strip of wires. Lift the large strip of wires out of the way to reveal the Wi-Fi Card.
  10. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 10, afbeelding 1 van 1
    • Use a non metallic item to pry up on the two metal clips holding the black and white wires. These should pop straight up and will be free from the Wifi Card.
  11. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 11, afbeelding 1 van 1
    • Use a small Philips screwdriver to remove the screw shown.
  12. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: stap 12, afbeelding 1 van 1
    • The Wi-Fi Card can now be unplugged from it's port and removed.
Conclusie
Elaine Butler
265 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-2, Beck Spring 2022 Lid van IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 33
Altijd: 443
