Inleiding
This guide will show you how to easily remove the Track Pad from a Toshiba Satellite C55D-B5206. This is a very easy process as shown in this guide.
Wat je nodig hebt
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
