Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 Trackpad Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Trackpad Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Trackpad Replacement, Trackpad: stap 6, afbeelding 1 van 1
    • Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
  7. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 7, afbeelding 1 van 1
    • Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
    • Gently pull the blue ribbon cable free.
  8. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 8, afbeelding 1 van 1
    • Use a small Philips screwdriver to remove the screw shown.
  9. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 9, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 9, afbeelding 2 van 2
    • Push the two gray tabs out on the large wire plug shown.
    • The tabs only need to be pressed out a few millimeters, not all the way.
    • The plug can now be carefully pulled out.
  10. Toshiba Satellite C55D-B5206 Trackpad Replacement: stap 10, afbeelding 1 van 1
    • Gently lift the trackpad to remove it.
Conclusie
Elaine Butler
265 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-2, Beck Spring 2022 Lid van IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 142
