Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Motherboard Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Motherboard Replacement, Fan: stap 6, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Motherboard Replacement, Fan: stap 6, afbeelding 2 van 2
    • Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
  7. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the copper heat sink to make the fan more accessible.
    • The copper heat sink should not detach. Do not pull on it too hard.
  8. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Maneuver the fan's bottom left corner above the copper heat sink.
  9. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Cautiously move the white cable cover to allow for the fan to be lifted away.
    • Do not detach the white cable cover.
  10. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Lift the fan approximately one inch upward from back of the laptop.
    • Detach the white cable connector from the connective port.
  11. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Once the cable port is detached, lift the fan free from the device.
  12. Toshiba Satellite C55D-B5206 Motherboard Replacement, Hard Drive: stap 12, afbeelding 1 van 1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  13. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  14. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 14, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  15. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 15, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 15, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 15, afbeelding 3 van 3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
  16. Toshiba Satellite C55D-B5206 Motherboard Replacement, Motherboard: stap 16, afbeelding 1 van 1
    • Remove all pieces of yellow polyimide tape that covers the connectors and cables on the motherboard.
  17. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 17, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 17, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 17, afbeelding 3 van 3
    • Unplug all wires from the motherboard. Large wires will be held in by gray plastic clips on the sides of the plugs that are to be pushed out. Smaller wires either pull straight out or will have a gray tab to lift out before pulling the wire out.
  18. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 18, afbeelding 1 van 1
    • Remove the three screws circled in the picture.
  19. Toshiba Satellite C55D-B5206 Motherboard Replacement: stap 19, afbeelding 1 van 1
    • Carefully remove the motherboard from the laptop.
Conclusie
Drew Fryman
193 Reputatie
2 handleidingen geschreven
IUPUI, Team 1-2, Beck Spring 2022 Lid van IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 330
