Inleiding
Hard disks may crash after long periods of use. In the event your hard drive crashes, or you simply desire to upgrade to a solid state drive. Replacing the hard drive is moderately easy and requires a few simple steps.
Wat je nodig hebt
Turn the laptop upside down so the battery faces upwards.
Remove the two 7 mm Phillips screws that secure the battery.
Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks.. Really helped out..
