Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 7, afbeelding 3 van 3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 8, afbeelding 2 van 2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: stap 9, afbeelding 3 van 3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Michelle
175 Reputatie
1 Handleiding geschreven
CSU Fullerton, Team 2-5, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Leden
18 handleidingen geschreven
2 opmerkingen
Thanks.. Really helped out..
SpeedyBlanco - Antwoord
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 4,732
