Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 Fan Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 Fan Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Fan Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Fan Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Fan Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Fan Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Fan Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Fan Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 Fan Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 Fan Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Fan Replacement, Fan: stap 6, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Fan Replacement, Fan: stap 6, afbeelding 2 van 2
    • Remove the three 7 mm Philips head screws by turning the screws counter clockwise.
  7. Toshiba Satellite C55D-B5206 Fan Replacement: stap 7, afbeelding 1 van 1
    • Gently lift the copper heat sink to make the fan more accessible.
    • The copper heat sink should not detach. Do not pull on it too hard.
  8. Toshiba Satellite C55D-B5206 Fan Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 Fan Replacement: stap 8, afbeelding 2 van 2
    • Maneuver the fan's bottom left corner above the copper heat sink.
  9. Toshiba Satellite C55D-B5206 Fan Replacement: stap 9, afbeelding 1 van 1
    • Cautiously move the white cable cover to allow for the fan to be lifted away.
    • Do not detach the white cable cover.
  10. Toshiba Satellite C55D-B5206 Fan Replacement: stap 10, afbeelding 1 van 1
    • Lift the fan approximately one inch upward from back of the laptop.
    • Detach the white cable connector from the connective port.
  11. Toshiba Satellite C55D-B5206 Fan Replacement: stap 11, afbeelding 1 van 1
    • Once the cable port is detached, lift the fan free from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tayyaba
523 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team 2-5, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 448
