Ga door naar hoofdinhoud
Toshiba Satellite C55D-B5206 CD Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 CD Drive Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 2, afbeelding 2 van 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 CD Drive Replacement, Back Casing: stap 3, afbeelding 1 van 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 4, afbeelding 1 van 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 CD Drive Replacement, CD Drive: stap 6, afbeelding 1 van 1
    • The 7 mm Philips#1 screw has been removed in the back casing removal.
    • Place thumb on the edge of the CD-ROM drive.
    • Gently slide the CD-ROM drive towards your palm.
  7. Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite C55D-B5206 CD Drive Replacement: stap 7, afbeelding 2 van 2
    • Lift away the CD-ROM drive.
    • You should feel the CD-ROM drive detach from the connector port.
    • The drive should slide out and lift away with little resistance. There is no need to slide the drive roughly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Tayyaba
523 Reputatie
4 handleidingen geschreven
CSU Fullerton, Team 2-5, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 682
