Ga door naar hoofdinhoud
Toshiba Satellite C55D-A5201 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 7, afbeelding 3 van 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 9, afbeelding 3 van 3
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: stap 10, afbeelding 2 van 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Kari Byrd
614 Reputatie
1 Handleiding geschreven
Baylor, Team 6-5, Shaver Spring 2015 Lid van Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 9
Altijd: 5,819
