Ga door naar hoofdinhoud
Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: stap 2, afbeelding 1 van 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: stap 3, afbeelding 1 van 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Remove the Phillips #0 screw from the memory cover.
  5. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: stap 5, afbeelding 1 van 1
    • Grasp the side of the hard drive opposite the circular battery, and carefully pull out the drive by moving it away from the circular battery.
  6. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: stap 6, afbeelding 1 van 3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: stap 6, afbeelding 2 van 3 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Back Cover: stap 6, afbeelding 3 van 3
    • Remove the 16 screws holding the back cover with a Phillips #0 screwdriver.
    • Pry the cover off with an opening tool.
    • Gently remove the cover with your hands and place to the side.
  7. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: stap 7, afbeelding 1 van 2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement, Wi-Fi Card: stap 7, afbeelding 2 van 2
    • Remove the single screw securing the Wi-Fi card using a Phillips #0 screwdriver.
  8. Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55D-A5108 Wi-Fi Card Replacement: stap 8, afbeelding 2 van 2
    • The card will pop up; gently pull the card out of the port.
    • Unplug the wireless antenna cables attached to the card.
    • Remember how the cables were connected to assure you do not cross the Bluetooth and wireless connections by accident.
Conclusie
Ryan Smith
187 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 919
