Ga door naar hoofdinhoud
Toshiba Satellite C55D-A5108 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: stap 3, afbeelding 1 van 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: stap 4, afbeelding 1 van 2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: stap 4, afbeelding 2 van 2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite C55D-A5108 Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Conclusie
Michael Medeiros
150 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S1-G5, O'Connell Fall 2019 Lid van UMass Dartmouth, Team S1-G5, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 244
