Ga door naar hoofdinhoud
Toshiba Satellite C55-C5268 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-C5268 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Hard Drive Replacement, Back Panel: stap 3, afbeelding 1 van 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Hard Drive Replacement, Hard Drive: stap 6, afbeelding 1 van 1
    • Pull the two rubber stops upward to move them out of the way and free the hard drive.
  7. Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Slide the hard drive to the right towards the stops. This disconnects it from the motherboard.
    • This will require some force to slide the hard drive.
  8. Toshiba Satellite C55-C5268 Hard Drive Replacement: stap 8, afbeelding 1 van 1
    • The hard drive can be lifted out for replacement.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Greg Smith
347 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-1, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 45
Altijd: 13,588
