Ga door naar hoofdinhoud
Toshiba Satellite C55-C5268 Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-C5268 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Battery Replacement: stap 2, afbeelding 2 van 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Greg Smith
347 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-1, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Leden
12 handleidingen geschreven
2 opmerkingen
Thanks, l think my battery is dead, charged it for 12 hours and base never got hot, not charging, right? Computer does not come on at all.
bribocall - Antwoord
Hello! i have TOSHIBA SATELLITE C55-B1065 Laptop and i’m wondering what is the good battery i should buy ?
sana aissaoui - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 130
Altijd: 16,451
