Ga door naar hoofdinhoud
Toshiba Satellite C55-C5268 Back Panel Replacement Guide
Wat je nodig hebt
  1. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Battery: stap 1, afbeelding 1 van 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 2, afbeelding 2 van 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Back Panel Replacement Guide, Back Panel: stap 3, afbeelding 1 van 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 4, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 4, afbeelding 2 van 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 5, afbeelding 1 van 2 Toshiba Satellite C55-C5268 Back Panel Replacement Guide: stap 5, afbeelding 2 van 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ben Rounseville
471 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 4-1, Catania Fall 2016 Lid van UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 1,827
