Ga door naar hoofdinhoud
Toshiba Satellite C55-C5240 Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-C5240 Screen Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Screen Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 2, afbeelding 3 van 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Screen Replacement, Back cover: stap 3, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Screen Replacement, Back cover: stap 3, afbeelding 2 van 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Screen Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Carefully disconnect these three cables.
  6. Toshiba Satellite C55-C5240 Screen Replacement: stap 6, afbeelding 1 van 1
    • Open the laptop at a right angle to make the later removal much easier.
  7. Toshiba Satellite C55-C5240 Screen Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 7, afbeelding 3 van 3
    • Unscrew the four PH1 Phillips head screws on the hinges.
  8. Toshiba Satellite C55-C5240 Screen Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Screen Replacement: stap 8, afbeelding 2 van 2
    • Separate the screen from the rest of the laptop.
    • Make sure the cables do not catch on the bottom piece.
  9. Toshiba Satellite C55-C5240 Screen Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 9, afbeelding 3 van 3
    • Using a pair of tweezers, remove the two stickers on the bottom of the screen.
    • Unscrew the two screws underneath.
  10. Toshiba Satellite C55-C5240 Screen Replacement: stap 10, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 10, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 10, afbeelding 3 van 3
    • Stick the plastic opening tool underneath the screen bezel and run it along the edge of the screen.
    • Loosen each hinge separately, it would be more difficult otherwise.
  11. Toshiba Satellite C55-C5240 Screen Replacement: stap 11, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 11, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 11, afbeelding 3 van 3
    • Unscrew the four inner screws around the screen.
    • Leave the two outer screws on the top alone.
  12. Toshiba Satellite C55-C5240 Screen Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Screen Replacement: stap 12, afbeelding 3 van 3
    • Mind the cable on the bottom of the screen.
    • Simply lift the screen out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Angela Rodriguez
261 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G5, Nance Spring 2017 Lid van USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 2,389
