Inleiding
The motherboard is a large and central part to the laptop. Most components either connect or interface with it in some manner. Because there is a lot involved, this guide will show how to remove it properly.
Wat je nodig hebt
Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
The hard drive is on the bottom left side.
Remove both releases from the rubber hard drive mount.
Slide the disk drive to the right and gently lift up the disk out the laptop.
4 andere personen hebben deze handleiding voltooid.
