Ga door naar hoofdinhoud
Toshiba Satellite C55-C5240 Motherboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 2, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 2, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: stap 3, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Motherboard Replacement, Back cover: stap 3, afbeelding 2 van 2
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  4. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 4, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 4, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  5. Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: stap 5, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: stap 5, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Hard Drive: stap 5, afbeelding 3 van 3
    • The hard drive is on the bottom left side.
    • Remove both releases from the rubber hard drive mount.
  6. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Lift the hard drive from underneath on the right side.
    • While holding it up, pull it away from its connector so that it disconnects.
  7. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Peel off the rubber hard drive mount.
  8. Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: stap 8, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement, Motherboard: stap 8, afbeelding 3 van 3
    • Slide the disk drive to the right and gently lift up the disk out the laptop.
  9. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Disconnect the 5 ribbon cables.
    • To remove, unlock the latch of each ribbon and pull it out.
  10. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 10, afbeelding 2 van 2
    • There is a wifi card underneath the large ribbon cable on the right.
    • Remove the plastic piece that covers the screw.
  11. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Unscrew the PH1 Phillips head 3.0 mm long screw holding it in.
    • Pull out the WiFi card.
  12. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Disconnect the 4 regular cables.
    • Carefully pull the cable parallel to the board, not up or at an angle.
  13. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 13, afbeelding 1 van 2 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Unscrew the seven PH1 Phillips head 3.0 mm long screws that hold the motherboard in place.
  14. Toshiba Satellite C55-C5240 Motherboard Replacement: stap 14, afbeelding 1 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 14, afbeelding 2 van 3 Toshiba Satellite C55-C5240 Motherboard Replacement: stap 14, afbeelding 3 van 3
    • Carefully lift the motherboard from the edges.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Abdel Feliciano Gonzalez
722 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G5, Nance Spring 2017 Lid van USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 50
Altijd: 7,005
