Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
If your battery is not working and you need to take it out, do the following steps to remove it properly.
  1. Make sure you turn off the laptop before starting. Remove the two 6.5mm PH1 Phillips screws securing the battery. Remove the two 6.5mm PH1 Phillips screws securing the battery.
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  3. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Conclusie
Abdel Feliciano Gonzalez
584 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G5, Nance Spring 2017 Lid van USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 19
Altijd: 781
