Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This is a guide that will assist you with replacing your RAM in a Toshiba Satellite C55-C5240.
Onderdelen
Geen onderdelen opgegeven.
  1. Make sure you turn off the laptop before starting. Remove the two 6.5mm PH1 Phillips screws securing the battery. Remove the two 6.5mm PH1 Phillips screws securing the battery.
    • Make sure you turn off the laptop before starting.
    • Remove the two 6.5mm PH1 Phillips screws securing the battery.
  2. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily. Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
    • Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  3. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  4. Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover. Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
    • Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
  5. Using the plastic opening tools, open the back cover and remove it from the laptop. It is recommended that you start from a corner and run the tool along the edge of the cover. Be careful not to bend or crack the cover.
    • Using the plastic opening tools, open the back cover and remove it from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  6. The RAM is at the upper middle area of the motherboard. Push down on the clips on either side of the RAM stick evenly. It will come loose in an angle once the clips are released.
    • The RAM is at the upper middle area of the motherboard.
    • Push down on the clips on either side of the RAM stick evenly.
    • It will come loose in an angle once the clips are released.
  7. Simply pull out the RAM stick.
    • Simply pull out the RAM stick.
    • These steps work for both sticks of RAM.
Conclusie
Angela Rodriguez
246 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G5, Nance Spring 2017 Lid van USF Tampa, Team S1-G5, Nance Spring 2017
USFT-NANCE-S17S1G5
3 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 865
