Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
Pull the battery from the back of the laptop for removal from the laptop.
Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
Push down on the two clips holding the RAM chip in place.
Pull the RAM chip up slightly and out away from the connection to remove.
