Ga door naar hoofdinhoud
Toshiba Satellite C55-B5302 Monitor Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 2, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 3, afbeelding 1 van 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: stap 4, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: stap 4, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Fan: stap 4, afbeelding 3 van 3
    • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 5, afbeelding 1 van 1
    • Disconnect the fan wire from the motherboard.
  6. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove the three 3 mm screws with a Phillips #00 screwdriver.
    • Remove the 5 mm screw with a Phillips #0 screwdriver.
  7. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 7, afbeelding 1 van 1
    • You can now lift the fan out of the laptop.
  8. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: stap 8, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: stap 8, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Screen Bezel: stap 8, afbeelding 3 van 3
    • After the fan has been removed, lift the hinge so as to get access to the parts below it.
    • Remove the the black colored cable that is now exposed.
  9. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 9, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 9, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 9, afbeelding 3 van 3
    • Remove the 7 mm Phillips #0 screw on the other hinge.
    • Remove the 3.1 mm Phillips #0 screw on the the same hinge.
    • Lift the hinge up and towards you.
  10. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 10, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 10, afbeelding 2 van 2
    • Pull out the wide cable to reveal the components underneath.
  11. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 11, afbeelding 2 van 2
    • Remove the 3.1 mm Phillips #0 screw holding the chip in place.
    • Pull out the chip.
  12. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 12, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 12, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 12, afbeelding 3 van 3
    • Hold the cable that is to be removed.
    • Use an iFixit opening tool to push down on the white protrusion of cable connector.
    • Now you can pull out the cable.
  13. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 13, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 13, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 13, afbeelding 3 van 3
    • Pivot and lift up the monitor and separate it from the base of the laptop.
  14. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 14, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 14, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 14, afbeelding 3 van 3
    • Use an iFixit opening tool to separate the two halves of the bezel starting at both the plastic hinges.
    • Use the metal spudger to separate the rest of the bezel.
    • Be careful not to scratch the screen with the metal spudger.
    • You may hear some sounds as the clips on the bezel disconnect from the back cover. This is normal.
  15. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: stap 15, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: stap 15, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Webcam: stap 15, afbeelding 3 van 3
    • Remove the three 4.1 mm Phillips #0 screws attaching each hinge to the screen.
  16. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 16, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 16, afbeelding 2 van 2
    • Remove the two 3.1 mm Phillips #0 screws at the top of the screen.
  17. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 17, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 17, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 17, afbeelding 3 van 3
    • Pull up on and turn over the screen to expose the wire connecting the webcam to the screen.
    • Be careful not to pull up on the screen too far and damage the wire.
  18. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 18, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 18, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 18, afbeelding 3 van 3
    • Once the screen has been detached and turned over, remove the webcam from its place on the bezel.
  19. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 19, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 19, afbeelding 2 van 2
    • Carefully, take off the tape connecting the webcam to the circuit board using a set of tweezers.
    • Once the tape has been removed, you can disconnect the webcam from the wire completely.
  20. Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: stap 20, afbeelding 1 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: stap 20, afbeelding 2 van 3 Toshiba Satellite C55-B5302 Monitor Screen Replacement, Monitor Screen: stap 20, afbeelding 3 van 3
    • Have the screen along with the metal hinges stand upright on one side.
    • Remove the three 3 mm Phillips #0 screws from the metal frame attached to the hinge.
    • Separate the metal frame from the rest of the screen.
  21. Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 21, afbeelding 1 van 2 Toshiba Satellite C55-B5302 Monitor Screen Replacement: stap 21, afbeelding 2 van 2
    • Repeat the previous steps to separate the metal frame on the other side.
Conclusie
Ebin Daniel
109 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G3, Henning Spring 2019 Lid van IUPUI, Team S1-G3, Henning Spring 2019
IUPUI-HENNING-S19S1G3
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 500
