Ga door naar hoofdinhoud
Toshiba Satellite C55-B5200 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-B5200 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
  4. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Use a plastic opening tool to lift and remove the bottom panel.
  5. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the six 2.3mm Phillips #0 screws from the motherboard.
    • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
  6. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite C55-B5200 Keyboard Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite C55-B5200 Keyboard Replacement: stap 6, afbeelding 3 van 3
    • Disconnect the wires from the motherboard.
    • Lift and remove the disk drive.
    • Lift and remove the hard drive.
  7. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Lift up the motherboard
    • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
  8. Toshiba Satellite C55-B5200 Keyboard Replacement: stap 8, afbeelding 1 van 2 Toshiba Satellite C55-B5200 Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Use a plastic opening tool to unlatch the keyboard from the device
    • Lift the keyboard off the laptop, careful of the IDE ribbon cable
Conclusie
Pablo Andrade
1.081 Reputatie
7 handleidingen geschreven
USF Tampa, Team S3-G1, Nance Spring 2018 Lid van USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Leden
22 handleidingen geschreven
Één opmerking
gracias por la guía
Mark Puga - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 3,774
