Ga door naar hoofdinhoud
Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: stap 3, afbeelding 1 van 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: stap 3, afbeelding 2 van 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: stap 3, afbeelding 3 van 3
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Pablo Andrade
1.081 Reputatie
7 handleidingen geschreven
USF Tampa, Team S3-G1, Nance Spring 2018 Lid van USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Leden
22 handleidingen geschreven
Één opmerking
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 4,540
