Inleiding
A guide on how to replace the fan on your Toshiba Satellite C55-B5200 laptop.
Wat je nodig hebt
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Remove the single 4.6mm Phillips #0 screw securing the fan.
Use a pair of tweezers to unplug the fan from the motherboard.
Pull the fan out.
Één andere persoon heeft deze handleiding voltooid.
