Inleiding
This guide will teach you how to disassemble the device in order to replace the Keyboard.
Wat je nodig hebt
Power down the laptop and remove all power cords. After this is done, turn the laptop over.
Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
Using your thumb, apply a light amount of pressure to the underside of the keyboard until it pops out a bit.
