Ga door naar hoofdinhoud
Toshiba Satellite C55-A5302 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-A5302 Hard Drive Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Hard Drive Replacement: stap 2, afbeelding 1 van 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Hard Drive Replacement, Hard Drive: stap 4, afbeelding 1 van 1
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Hard Drive Replacement: stap 6, afbeelding 1 van 1
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Hard Drive Replacement: stap 7, afbeelding 1 van 1
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 656
