Inleiding
This guide will help you if you need to replace the CD Drive in your laptop. Replacing the CD Drive will fix any issues caused by an old or faulty CD Drive. It is very straightforward and can be completed regardless of technical knowledge or skill level.
Wat je nodig hebt
With the Laptop off, turn it over.
The battery is located next to the screen hinges.
Move the locking tab located directly above the battery on the right side, all the way to the left. It will stay in place by itself.
Unscrew the screw on the back panel of the laptop covering the hard drive.
Remove the screw to the top right of the hard drive using the PH1 screwdriver.
