Ga door naar hoofdinhoud
Toshiba Satellite C55-A5286 Optical Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-A5286 Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 1
    • Unplug the AC adapter and all other auxiliary components from the laptop
  2. Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
  3. Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
  4. Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 4, afbeelding 1 van 1
    • Under the back panel, remove the 4-mm screw holding the disk drive in place.
  5. Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite C55-A5286 Optical Drive Replacement: stap 5, afbeelding 2 van 2
    • Carefully slide the optical drive out of its place in the laptop.
Conclusie
Nicole Zellers
265 Reputatie
2 handleidingen geschreven
IUPUI, Team S1-G5, Hovde Fall 2018 Lid van IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Leden
9 handleidingen geschreven
Één opmerking
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
William Totman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 12
Altijd: 293
