Inleiding
This guide will show you how to remove or replace the battery of the Toshiba Satellite C55-A5286 laptop. No tools are necessary for this procedure.
  1. Be sure to unplug the AC adapter and all other components from the laptop. Slide the battery release tab away from the center of the laptop and hold it in place. Slide the battery release tab away from the center of the laptop and hold it in place.
    • Be sure to unplug the AC adapter and all other components from the laptop.
    • Slide the battery release tab away from the center of the laptop and hold it in place.
  2. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  3. Lifting from the small notch between the two tabs, pull the battery out of the laptop. Lifting from the small notch between the two tabs, pull the battery out of the laptop.
    • Lifting from the small notch between the two tabs, pull the battery out of the laptop.
Conclusie
You have now taken the battery out of the laptop. To reassemble your device, follow these instructions in reverse order, being sure to snap the battery back into place.
Één andere persoon heeft deze handleiding voltooid.
Sabria Abufares
189 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G5, Hovde Fall 2018 Lid van IUPUI, Team S1-G5, Hovde Fall 2018
IUPUI-HOVDE-F18S1G5
2 Leden
3 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 2
Altijd: 46
