Ga door naar hoofdinhoud
Toshiba Satellite C55-A5140 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-A5140 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Make sure that the device is unplugged, completely off, and that the device is not warm to the touch.
    • Working from left to right, use plastic opening tool to lift keyboard up and out of recessed holding tray.
    • Continue to pry around the entire keyboard until it is loose enough to easily slide your fingers underneath the corners of the keyboard.
    • Once existing keyboard is removed, it can no longer be reinstalled. Be sure to have new keyboard available for installation.
    • Keyboard will make a snapping sound as it is freed from tray.
  2. Toshiba Satellite C55-A5140 Keyboard Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite C55-A5140 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Using hands, gently pull keyboard out of device.
Conclusie
To reassemble your device, use tabs on new keyboard to snap into keyboard tray
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 496
