Ga door naar hoofdinhoud
Toshiba Satellite C55-A5100 RAM Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite C55-A5100 RAM Replacement: stap 4, afbeelding 2 van 2
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: stap 5, afbeelding 1 van 1
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: stap 6, afbeelding 1 van 1
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
Conclusie
Walker Tortorigi
495 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 16
Altijd: 348
