Ga door naar hoofdinhoud
Toshiba Satellite C55-A5100 Keyboard Replacement
Wat je nodig hebt
  1. Toshiba Satellite C55-A5100 Keyboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 Keyboard Replacement, Keyboard: stap 3, afbeelding 1 van 1
    • On the back of the laptop, remove the 6mm Phillips #1 screw. This screw is attached to the keyboard.
  4. Toshiba Satellite C55-A5100 Keyboard Replacement: stap 4, afbeelding 1 van 1
    • Looking at the keyboard, locate the eight clips that hold it in place.
  5. Toshiba Satellite C55-A5100 Keyboard Replacement: stap 5, afbeelding 1 van 2 Toshiba Satellite C55-A5100 Keyboard Replacement: stap 5, afbeelding 2 van 2
    • Use the plastic opening tool to slide the clips back, releasing the keyboard.
    • As you release the clips, use the plastic opening tool to lift keyboard above the clips.
  6. Toshiba Satellite C55-A5100 Keyboard Replacement: stap 6, afbeelding 1 van 1
    • Once the keyboard is released from the clips you should be able to lift it up, exposing the wire connecting it to the laptop.
    • The keyboard will slide out of the clips on the top.
  7. Toshiba Satellite C55-A5100 Keyboard Replacement: stap 7, afbeelding 1 van 1
    • Using your fingers, slowly pull the wire out of its connection.
    • The keyboard is now disconnected.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Walker Tortorigi
495 Reputatie
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 905
