Ga door naar hoofdinhoud
Toshiba Satellite A85-S107 15" Fan Replacement
Wat je nodig hebt
  1. Toshiba Satellite A85-S107 15" Fan Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Fan Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Fan Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite A85-S107 15" Fan Replacement: stap 3, afbeelding 2 van 2
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Fan Replacement, Keyboard: stap 4, afbeelding 1 van 1
    • Flip the laptop over so that the front tab of the laptop faces you.
  5. Toshiba Satellite A85-S107 15" Fan Replacement: stap 5, afbeelding 1 van 3 Toshiba Satellite A85-S107 15" Fan Replacement: stap 5, afbeelding 2 van 3 Toshiba Satellite A85-S107 15" Fan Replacement: stap 5, afbeelding 3 van 3
    • Unlock the laptop by sliding the front tab to the right.
    • Open the laptop by lifting the screen up while holding the tab in place.
  6. Toshiba Satellite A85-S107 15" Fan Replacement: stap 6, afbeelding 1 van 3 Toshiba Satellite A85-S107 15" Fan Replacement: stap 6, afbeelding 2 van 3 Toshiba Satellite A85-S107 15" Fan Replacement: stap 6, afbeelding 3 van 3
    • Place the laptop on its left side with the disk drive facing up and the screen open completely.
    • Locate the rectangular slot on the side of the laptop just above the disk drive.
    • Insert the flat end of the spudger into the rectangular slot.
  7. Toshiba Satellite A85-S107 15" Fan Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite A85-S107 15" Fan Replacement: stap 7, afbeelding 2 van 2
    • Insert the opening tool into the rectangular slot with the spudger.
    • Pry off the top part of the laptop's case (above the keyboard) containing the speakers by using both the spudger and opening tool to push the case away from the computer.
    • Once the top part of the laptop's case has been popped off, use your hands to remove it.
  8. Toshiba Satellite A85-S107 15" Fan Replacement: stap 8, afbeelding 1 van 1
    • Place the laptop on a level surface with the keyboard facing you.
  9. Toshiba Satellite A85-S107 15" Fan Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 5mm Phillips #1 screws which hold the keyboard in place.
  10. Toshiba Satellite A85-S107 15" Fan Replacement: stap 10, afbeelding 1 van 1
    • Unhook the plastic tab at the top of the keyboard using the plastic opening tool to pry the top of the keyboard up.
  11. Toshiba Satellite A85-S107 15" Fan Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite A85-S107 15" Fan Replacement: stap 11, afbeelding 2 van 2
    • Lift up the keyboard from the back end where the function keys are located.
    • Slide the keyboard out towards the screen.
    • Be careful not to rip the ribbon out of its port.
    • This may damage your laptop.
  12. Toshiba Satellite A85-S107 15" Fan Replacement: stap 12, afbeelding 1 van 1
    • Pull the ribbon wire attaching the keyboard to the computer out of its port.
    • Before you pull try to hold the ribbon wire as close to the port as possible to prevent it from breaking.
  13. Toshiba Satellite A85-S107 15" Fan Replacement, Fan: stap 13, afbeelding 1 van 2 Toshiba Satellite A85-S107 15" Fan Replacement, Fan: stap 13, afbeelding 2 van 2
    • Locate and Remove the three 5mm Phillips #0 screws.
  14. Toshiba Satellite A85-S107 15" Fan Replacement: stap 14, afbeelding 1 van 1
    • Pull the end of the white wire clip out of its port.
  15. Toshiba Satellite A85-S107 15" Fan Replacement: stap 15, afbeelding 1 van 1
    • Take out the fan by lifting it out of its dock.
Conclusie
Alana
96 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-38, Amido Spring 2013 Lid van Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 792
