Ga door naar hoofdinhoud
Toshiba Satellite A85-S107 15" Back Panel Replacement
Wat je nodig hebt
  1. Toshiba Satellite A85-S107 15" Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 2, afbeelding 1 van 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 3, afbeelding 1 van 1
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 4, afbeelding 2 van 2
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 5, afbeelding 1 van 1
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. Toshiba Satellite A85-S107 15" Back Panel Replacement: stap 6, afbeelding 1 van 1
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Shravani Kakarla
107 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-5, Cichon Spring 2014 Lid van UMass Dartmouth, Team 1-5, Cichon Spring 2014
UMASSD-CICHON-S14S1G5
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 575
