Wat je nodig hebt
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
Then remove the fourteen 8.6 mm screws from the bottom of the case.
Bijna klaar!
Conclusie
