Ga door naar hoofdinhoud
Toshiba Satellite A75-S226 Heat Sink Replacement
Wat je nodig hebt
  1. Toshiba Satellite A75-S226 Heat Sink Replacement, Battery: stap 1, afbeelding 1 van 1
    • Make sure battery-lock is in the unlock position.
    • Slide button to the left.
  2. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 2, afbeelding 1 van 1
    • Lift battery out of the computer.
  3. Toshiba Satellite A75-S226 Heat Sink Replacement, Optical Drive: stap 3, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Optical Drive: stap 3, afbeelding 2 van 2
    • Remove the two 5.62 mm screws from the optical drive cover.
  4. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 4, afbeelding 2 van 2
    • Remove the optical drive cover.
    • A plastic opening tool or a fingernail may be helpful in lifting it from its groove.
  5. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 5, afbeelding 1 van 1
    • Using the inset divot, push the optical drive out of the laptop to remove.
  6. Toshiba Satellite A75-S226 Heat Sink Replacement, CD Drive: stap 6, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, CD Drive: stap 6, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, CD Drive: stap 6, afbeelding 3 van 3
    • Remove the 8.6 mm screw.
  7. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 7, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 7, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 7, afbeelding 3 van 3
    • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
    • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
  8. Toshiba Satellite A75-S226 Heat Sink Replacement, Wi-Fi/Memory Cover: stap 8, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Wi-Fi/Memory Cover: stap 8, afbeelding 2 van 2
    • Remove the 5.75 mm screw from the cover panel.
    • Turn the laptop over with the screen facing down.
  9. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 9, afbeelding 1 van 1
    • Lift up the cover panel using a plastic opening tool.
  10. Toshiba Satellite A75-S226 Heat Sink Replacement, Wi-Fi Card: stap 10, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Wi-Fi Card: stap 10, afbeelding 2 van 2
    • Remove the 5.64 mm screw from the bottom of the crossing bar.
    • Remove the crossing bar.
  11. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 11, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 11, afbeelding 2 van 2
    • Use a plastic opening tool to disconnect the black and white antenna cable's connectors from the Wi-Fi card.
    • Note that the black wire is connected to the port that is labeled main.
  12. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 12, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 12, afbeelding 2 van 2
    • Use fingers to push the clips away from memory card.
  13. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 13, afbeelding 1 van 1
    • Use fingers to remove the Wi-Fi card.
  14. Toshiba Satellite A75-S226 Heat Sink Replacement, Keyboard: stap 14, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, Keyboard: stap 14, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, Keyboard: stap 14, afbeelding 3 van 3
    • Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
    • It may be helpful to first pry at the rear of the hinge covers (not shown) to release them. Then Insert the plastic opening tool underneath the top panel's sides and then front edge.
  15. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 15, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 15, afbeelding 2 van 2
    • Remove the top panel by popping the panel out the top left socket, then do the same with the right side.
  16. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 16, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 16, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 16, afbeelding 3 van 3
    • Remove the two 3.67 mm screws from the top corners of the keyboard.
  17. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 17, afbeelding 1 van 1
    • Use fingers to lift up the keyboard from the top.
    • Do not try to remove the keyboard completely because it is still attached to the motherboard.
  18. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 18, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 18, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 18, afbeelding 3 van 3
    • Remove the cable connecting the keyboard with the motherboard.
    • Be aware of the locking tabs on each side of the ribbon-cable connector—they slide back about 2mm to free the cable.
    • Lift up and remove the keyboard.
  19. Toshiba Satellite A75-S226 Heat Sink Replacement, Display Assembly: stap 19, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Display Assembly: stap 19, afbeelding 2 van 2
    • Remove the 3.76mm screw from the ground wire.
  20. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 20, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 20, afbeelding 2 van 2
    • Use the plastic opening tool to remove the wire.
  21. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 21, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 21, afbeelding 2 van 2
    • Gently pull the black and white wires out of the upper case.
    • Do not pull the wire too much, or you can damage the wire.
  22. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 22, afbeelding 1 van 1
    • Remove the 8.6 mm screw on left side of upper case.
  23. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 23, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 23, afbeelding 2 van 2
    • Remove two 8.6 mm screws on the back corners of the laptop.
  24. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 24, afbeelding 1 van 1
    • Lift up the display assembly to remove it.
  25. Toshiba Satellite A75-S226 Heat Sink Replacement, Upper Case: stap 25, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Upper Case: stap 25, afbeelding 2 van 2
    • Use the Phillips screwdriver to remove the two 3.7 mm screws from the battery compartment.
    • Then remove the fourteen 8.6 mm screws from the bottom of the case.
  26. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 26, afbeelding 1 van 1
    • Use the screwdriver to remove six 8.6 mm screws from the top of the case.
  27. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 27, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 27, afbeelding 2 van 2
    • Use the plastic opening tool to remove the two speaker wire connectors and the trackpad connector from the motherboard.
  28. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 28, afbeelding 1 van 1
    • With the plastic opening tool, pry around the entire laptop to separate the upper case.
  29. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 29, afbeelding 1 van 1
    • Lift up the upper case to remove.
  30. Toshiba Satellite A75-S226 Heat Sink Replacement, Motherboard: stap 30, afbeelding 1 van 1
    • Using the Phillips Screwdriver, remove the two 8.6 mm screws from the front edge of the motherboard.
  31. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 31, afbeelding 1 van 1
    • Remove the four screws holding the ports to the rear panel using the 3/16" Wrench.
  32. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 32, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 32, afbeelding 2 van 2
    • Lift up on the front edge of the motherboard while gently prying the case away from the ports on the right side of the computer.
    • Repeat with the left side.
    • There is a button for the card slot on the left side of the computer that may pop out if pressed. This button must be held in place while removing the motherboard.
  33. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 33, afbeelding 1 van 1
    • Lift the motherboard's front edge up and then slide it forward.
  34. Toshiba Satellite A75-S226 Heat Sink Replacement, Fans: stap 34, afbeelding 1 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, Fans: stap 34, afbeelding 2 van 3 Toshiba Satellite A75-S226 Heat Sink Replacement, Fans: stap 34, afbeelding 3 van 3
    • Remove cables connecting the fans with the motherboard.
  35. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 35, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 35, afbeelding 2 van 2
    • Turn over the motherboard.
    • Remove the four silver screws with a Phillips screwdriver.
  36. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 36, afbeelding 1 van 1
    • Lift the fans up to remove them from the motherboard.
  37. Toshiba Satellite A75-S226 Heat Sink Replacement, Heat Sink: stap 37, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement, Heat Sink: stap 37, afbeelding 2 van 2
    • With the phillips screwdriver remove the four screws holding the heatsink on the motherboard.
  38. Toshiba Satellite A75-S226 Heat Sink Replacement: stap 38, afbeelding 1 van 2 Toshiba Satellite A75-S226 Heat Sink Replacement: stap 38, afbeelding 2 van 2
    • Lift heatsink off the motherboard.
    • There is thermal paste on the underside of the heatsink.
    • When reassembling the heatsink the thermal paste will need to be replaced.
Conclusie
Garrett Gudgel
763 Reputatie
13 handleidingen geschreven
Cal Poly, Team 4-43, Amido Fall 2010 Lid van Cal Poly, Team 4-43, Amido Fall 2010
CPSU-AMIDO-F10S4G43
5 Leden
39 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 6,076
