Inleiding
This guide may be useful for fixing dead pixels, cracked screens, and other problems with the display. You will need the iFixit plastic opening tool, a Phillips #1 screw driver, and your new Toshiba Satellite A75-S226 Display Assembly.
Wat je nodig hebt
Remove the 5.64 mm screw from the bottom of the crossing bar.
Remove the crossing bar.
Use the plastic opening tool to lift up the top panel all the way along the keyboard until it loosens.
Replace the old display assembly with your new assembly. To reassemble your device, follow these instructions in reverse order.
