Ga door naar hoofdinhoud
Toshiba Satellite A665-S5170 Hard Drive Replacement
Wat je nodig hebt
  1. Toshiba Satellite A665-S5170 Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn the computer upside down so that the bottom of the laptop is facing up.
    • Position the laptop so that you are able to read the words printed on the labels on the bottom of the laptop from left to right, and so that the laptop's hard drive panel is in the upper right-hand corner of the bottom of the computer.
    • Using a Phillip’s head 0 screwdriver, remove the 2mm Phillips head screw on the right side of the cover of the hard drive panel by rotating it counter-clockwise.
  2. Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Insert something thin, such as your nail or a credit card, into the slot on the right side of the cover of the hard drive panel.
    • Pull your finger up to pop off the cover of the hard drive panel.
  3. Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 3, afbeelding 1 van 2 Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 3, afbeelding 2 van 2
    • Gently push down on the hard drive with your hand.
    • Still pressing down on the hard drive, move your hand to the right in order to slide the hard drive to the right and to disconnect it from the computer.
  4. Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 4, afbeelding 1 van 2 Toshiba Satellite A665-S5170 Hard Drive Replacement: stap 4, afbeelding 2 van 2
    • To pull out the hard drive, pinch the plastic tab attached to the right of the hard drive with your thumb and index finger.
    • Gently lift the hard drive from the panel by pulling up on the plastic tab.
Conclusie
Chelsea Teague
385 Reputatie
2 handleidingen geschreven
Baylor, Team 4-5, Williams Fall 2016 Lid van Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 1,857
