Ga door naar hoofdinhoud
Toshiba Satellite A665-S5170 Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite A665-S5170 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Toshiba Satellite A665-S5170 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Turn the computer upside-down so that the bottom of the laptop is facing up.
    • Position the computer so that you are able to read the words on the labels on the bottom of the laptop from left to right.
    • Using the tip of your finger, slide the right clasp of the battery panel horizontally to the right until it locks into place.
  2. Toshiba Satellite A665-S5170 Battery Replacement: stap 2, afbeelding 1 van 1
    • Slide the left clasp of the battery panel horizontally to the left, and hold it in place.
    • You will have to continue holding the left clasp of the battery panel in place for future steps in order to remove the battery.
  3. Toshiba Satellite A665-S5170 Battery Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite A665-S5170 Battery Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite A665-S5170 Battery Replacement: stap 3, afbeelding 3 van 3
    • While continuing to hold the left clasp of the battery panel in place, slide out the old battery by pulling it towards you.
Conclusie
Chelsea Teague
385 Reputatie
2 handleidingen geschreven
Baylor, Team 4-5, Williams Fall 2016 Lid van Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 20
Altijd: 1,174
