Ga door naar hoofdinhoud
Toshiba Satellite A660-ST3NX2X Screen Replacement
Wat je nodig hebt
  1. Toshiba Satellite A660-ST3NX2X Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 2, afbeelding 2 van 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: stap 4, afbeelding 1 van 2 Toshiba Satellite A660-ST3NX2X Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • Unplug all devices and power down the computer completely.
    • Peel back all four circular stickers that are located at each corner of the computer frame.
    • A pair of fine point tweezers was used to complete this.
  5. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 5, afbeelding 1 van 1
    • Unscrew all four 5mm screws located underneath the stickers in each corner of the computer frame.
    • The computer frame should become more loose after the screws are removed.
  6. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 6, afbeelding 1 van 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 6, afbeelding 2 van 2
    • Pry the frame of the screen away from the computer.
    • A prying tool was used by inserting it in the crack between the frame and the screen and running it along the edges of the frame.
  7. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 7, afbeelding 1 van 2 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the three black 4mm JIS screws on each side of the metal frame that is still attached to the side of the screen.
    • Only two screws are shown in the image.
    • The metal frame will completely separate from the computer screen.
  8. Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 8, afbeelding 1 van 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 8, afbeelding 2 van 3 Toshiba Satellite A660-ST3NX2X Screen Replacement: stap 8, afbeelding 3 van 3
    • Position the screen in a way that the aluminum backing is exposed.
    • Peel off the metal-like attachment from the back of the screen.
Conclusie
Megan Murrell
322 Reputatie
3 handleidingen geschreven
Texas Tech, Team S8-G1, Bennett Spring 2017 Lid van Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 475
