Ga door naar hoofdinhoud
Toshiba Satellite A660-ST3NX2X Battery Replacement
Wat je nodig hebt
  1. Toshiba Satellite A660-ST3NX2X Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Battery Replacement: stap 2, afbeelding 1 van 2 Toshiba Satellite A660-ST3NX2X Battery Replacement: stap 2, afbeelding 2 van 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Battery Replacement: stap 3, afbeelding 1 van 3 Toshiba Satellite A660-ST3NX2X Battery Replacement: stap 3, afbeelding 2 van 3 Toshiba Satellite A660-ST3NX2X Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
Conclusie
Megan Murrell
322 Reputatie
3 handleidingen geschreven
Texas Tech, Team S8-G1, Bennett Spring 2017 Lid van Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 11
Altijd: 505
